2011 Mac mini (Radeon 6630M) Way Underperforming?
I picked up one of these Macs cheap on ebay. I was formerly using a 2010 mini with the nVidia 320m integrated GPU for classic retro gaming. The system is connected to a TV and a PS4 controller. I mainly play emulated via OpenEMU, and also bootcamp into windows 10 to play GTA Vice City and GTA San Andreas.
Somehow I completely forgot that Apple ever made a discrete GPU Mac mini. Having realized that, I looked up GPU benchmarks and found that the 6630m GPU is kind of decent. Many times mower powerful than the 320m that came before it, or the Intel HD 4000 that came after it. Based on benchmarking the 6630m vs the minimum GPU system requirements for GTA4, I should be able to play that game on it too!
Those are the specs. Now here's the reality. The mini's GPU runs really good for half a minute or so? Then the fan in the mini maxes out, and the GPU throttles so bad, the framerate tanks. IN FACT, its so bad, that I had to dial back the graphics settings in GTA San Andreas to MATCH what I play on the nVidia 320m!!! So on a Mac with over 3x the GPU performance, I'm effectively getting the exact same amount of real-world performance.
My first thought was, Windows 10 must be broken, I should revert to Windows 7!
But after continued use, I'm not sure that's the issue. The second most obvious problem might be bad thermal paste? I know that replacing thermal paste on Macs is all the rage these days, but its not usually as effective as "reddit" would make it seem. But that said, I am in a case where I'm trying to max this machine out. So maybe its worth while to pop off the heat sink, clean it all down, and put some fresh paste on it? If I do go this route, is it worth buying some fancy kind of paste, or will any new, unopened paste be fine?
Any other thoughts on what might be going on? I would be very happy if I could use this mini to play GTA:SA at full native 1080p, and if I could play GTA4 at any decent, playable graphics level.
Bu iyi bir soru mu?
