Ana içeriğe geç
Önden motorlu, arkadan çekişli tam boy bir sedan olan 4. nesil Chevy Caprice için onarım rehberleri ve destek. Impala SS ve Buick Roadmaster gibi diğer GM B-platformu araçlarıyla yakından ilişkilidir.
Car cut off while driving
Car drive but cut off
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Is the car shutting off when the gas is pressed, or when coming to a stop? What year model is it?
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
First step is too determine if the problem is fuel related or ignition. Start with a code scan and solve any engine related codes. If that doesn't fix it then when the engine dies, check for spark, if you have no spark fix that problem. It could be the module, the reluctor, the cap or rotor, the ignition coil, ignition wires even the spark plugs.
If the engine has spark when it dies, put a fuel pressure gauge on the engine. If the engine quits and has no fuel pressure then the problem is the fuel system. It could be the ECM, wiring, relay, fuse or the pump.
Obviously this diagnosis if not for the faint of heart nor the uninitiated. Your best bet may be a mobile mechanic. The car is rather old so an older mechanic may be more familiar with your cars systems.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Mike Jones sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 40
Her zaman: 161
