Brother MFC-8460N Printer Error
My brother printer always displays this error when i power it on..it lights a red blight then displays this error message..Machine Error. Contact Technical Support
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@onneilecas43557 following the MACHINE ERROR you should see another error code appear on the LCD. If not then check to see if this will tell you how to possibly finding the real error code. Just check 8.4.16
Now, if all you are getting is the The "Machine Error. Contact Technical Support" message then this is very generic for a mechanical failure. Could be the fuser or even the scanner malfunction. You would have to work through the troubleshooting section of the Brother Fax MFC 8460 Parts & SM for your printer.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 112
