Error code F08 - Troubleshoot
Hi everyone,
I’m troubleshooting my Whirlpool FWG8168BV that’s throwing an F08 error code, and I’d really appreciate some input.
Initial behavior:
- On a 30°C cycle, the machine starts normally (fills with water, drum rotates both directions).
- After about 10 minutes, it stops, drains itself, and shows F08.
Current behavior:
- Now it throws the F08 error immediately when starting a wash.
What I’ve checked so far:
- Heating element: Resistance measures within expected range. Removed and inspected, no visible damage. Also powered it directly and it heats up quickly.
- NTC sensor: Resistance changes correctly with temperature, seems functional.
- Voltage at heating element: Measured during a 30°C cycle, reads 0V.
- Relays (on PCB): Tested off-board with 9V, confirmed they click and switch correctly.
Where I’m stuck:
- I’m not sure how to verify if the relays are actually receiving the control/drive voltage during operation.
- Could the issue be upstream (control board logic)?
- Is it possible the pressure switch is not signaling correct water level, preventing heating?
Has anyone seen a similar issue or can point me in the right direction for further diagnostics?
Thanks in advance!
Bu iyi bir soru mu?
