Ana içeriğe geç
HP tarafından Aralık 2020'de piyasaya sürülen bir Intel iş dizüstü bilgisayarı olan HP EliteBook 840 G8 için onarım rehberleri, söküm bilgileri ve sorun giderme bilgileri.
How to fix EliteBook 840 G8
How to fix EliteBook 840 G8:
The keyboard light is not working, and how to fix any problem with it
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
@abebetazeba, double-check your motherboard. IT is possible that you are not getting any power to the keyboard backlight circuit. For a deep dive on that, it will be printed on your motherboard. Common board number would be a 6050A3217501-MB-A01
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi!
The backlit keyboard was optional.
Are you sure that your keyboard support it?
Before you order a new keyboard, please check if the motherboard does have the connector on it. most of the time it’s already on there, but please check first.
Be aware: they are not cheap as the keyboard is fused with the top cover. So you will replace them both.
IF your keyboard did support it, but it’s simply just broken, it’s most Of the time related to the backlit cable. This one is fused with the keyboard, so you need to replace it, to get it working again.
Guide: HP EliteBook 840 G7 klavye değişimi
Little side note: The HP Elitebook 840 G7 keyboard is compatible as well. The process is nearly the same.
Please let me know if you have any questions!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Abebe Tazeba sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 139
