Ana içeriğe geç
A2115 / 2020 / 3.1 GHz 6 çekirdekli i5'ten 3.8 GHz 8 çekirdekli i7'ye kadar işlemci seçenekleri. 4 Ağustos 2020'de piyasaya sürüldü.
SDD ribbon cable replacement
I have a bare 820-01779-A logic board and am trying to identify a small ribbon cable connector on the screen-facing side of the board. There are no SATA connectors on the heatsink side as seen on 2019 boards. Can anyone identify what this ribbon connector is and whether it has any relation to SATA storage?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
The 2020 model dropped the SATA port and even the Blade SSD! This series has soldered on Flash chips on the logic board on the base models and only on the high end give you access to more SSD storage via a custom flash (NAND) module. I haven seen this model personally, I suspect it's the same as the iMac Pro 27" 2020 iMac specs
Bottom line you can't upgrade or expand this systems storage internally.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
pdstreeter@hotmail.co.uk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 83
