Ana içeriğe geç
DualShock serisinin devamı olan dördüncü nesil Sony PlayStation 5 DualSense oyun kolu için onarım rehberleri, söküm ve sorun giderme bilgileri. CFI-ZCT1W model numarası ve BDM-040 anakart modeli ile tanımlanır.
What the problem with my x button
Resim
Resim
Resim
Resim
Resim
Resim
So the problem is that I was given a PS5 controller, but when I turned it on, the X button didn’t work, so I couldn’t log into any account. I opened the controller and did some cleaning I found online, but even after that it still didn’t work. I even removed the rubber piece from the PS button and tried to make contact with the X button membrane, but it still didn’t work.
I know it’s not a problem with the rubber because I used the same PS button rubber and touched the circle button membrane, and on the PS5 the controller registered a back action. That’s why I’m asking, because I don’t know if it’s a circuit issue or something with the pins, and I also don’t know how to fix it. I imagine it would require soldering, and I’m not very good at that and don’t have the right tools.
Whoever can help me, I would really appreciate it.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi!
In this case, I would replace the button circuit membrane.
You don’t need to solder for this.
Before you replace it, make sure you got the exact same model as the one that came out.
If you need guides, please let me know!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Jahdread Manso sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 233
