Ana içeriğe geç
Toyota Vitz, ilk olarak 1999 yılında Toyota Starlet'in halefi olarak piyasaya sürülen bir alt kompakt hatchback modelidir. Uluslararası pazarda Toyota Yaris veya Echo adıyla satılmaktadır. Günümüzde 4 nesil Toyota Vitz bulunmaktadır.
Oil in spark plugs
My car has oil in the spark plugs resulting into jerking of the engine and the engine light being on along with the abs light too.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@vijayveera44109 let us know what year and what engine size your Vitz is. As for the ABS light that is something you will have to get the OBDII scanned since there are to numerous errors.
As for your oil in the park plugs, there are many different reasons. wE will need to see what you sparkplugs look like. Take a couple of well focused pictures of the spark plug face so we can see what you see. Most commonly, you do want to go ahead and do a compression test as well as a leakdown test on your engine. That way you get a pretty good idea about what is going on. Could be bad valves, bad piston rings, and even a bad PCV valve. Check your sparkplugs against this
Resim
Mevcut bir soruya görsel ekleme
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Vijay Veeraragavoodoo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 27
Her zaman: 95
