How I can fix climate control part
The driver side it’s giving heat when I control climate it’s dose not give cooling
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@jasneetsingh sounds like your Passat may have issues with the cold air flap. Easiest way to diagnose that would be to have your Passat scanned with the right VW scanner. Otherwise, look through the VW Passat B8 Heating Air Conditioningchapter from the workshop manual. Check the flaps as well as the flap motors. Working on the HVAC system is a bit of a pain and it really should not be this complex. You can get the rest of the SM from this page 2016-2023 Volkswagen Passat
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 176
2 Yorum
@jasneetsingh just to make sure we understand you correctly, you get heat from the driver side vent but you do not get cold air from the same vent when you turn your climate control on. Is that correct? Also, do you get hot and cold air on the passenger side?
oldturkey03 tarafından
Yes temperature door left side
Jasneet Singh tarafından
