Ana içeriğe geç
Numatic tarafından üretilen Henry Elektrikli Süpürge.
Power cut and not working
Not working. Power cut
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Like @rodolfomeave, I'm not familiar with your particular vacuum, but I had the same issue with a Harbor Freight shop vac.
By testing the power going to the fan motor, I finally isolated it to a failed thermal fuse on one of the motor leads. These are designed to blow when the temperature exceeds a particular limit, but I have no reason to think mine was anywhere near that range when it blew. Anyway, replacing the fuse got the vacuum up and running again and I haven't had an issue with it since. Here's the part I purchased; yours will probably look similar, although you'll need to use the markings on it to determine what value to use for a replacement.
10pcs 10A 250V TF thermal protection Rice cooker fuse RY-65 75 80 100 120 175 185 210 230 280 Metal shell Temperature Fuse - AliExpress 502
Resim
Good luck, and be sure to come back and let us know what you find!
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
I do not have a Henry Vacuum, but if you are still having power issues there are some troubleshooting checks that you can do:
  • Make sure power cord is fully connected to power outlet
    • If outlet is a GFCI, also known as GFI, outlet; Make sure the breaker is not disconnected
  • Inspect power cord for any hard kinks, cuts, or anything that could potentially have broken the copper wire inside
  • Inspect for broken or loose power switch
  • Inspect internal wiring and PCB for broken connection, burnt components
Hopefully this helps!
Puan 0
Yorum Ekle
Yanıtını ekle
Bob sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 19
Son 30 gün: 51
Her zaman: 255
