Ana içeriğe geç
Battery problem very fast finish
How do increase my phone battery
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
1. Adjust the Refresh Rate
By default, the phone is often set to 120Hz, which makes scrolling smooth but drains the battery significantly faster.
  • Go to Settings > Display > Refresh Rate.
  • Switch from "Default" or "120Hz" to 60Hz. If you prefer the smoothness, select Custom and see if "Auto" helps, but 60Hz is the biggest battery saver.
2. Network Tweak: Switch to 4G/LTE
If you are in an area where 5G signal is weak, your phone will constantly "hunt" for a 5G tower, which generates heat and kills the battery.
  • Go to Settings > SIM cards & mobile networks > Preferred network type.
  • Select Prefer LTE or 4G. You will likely notice a cooler phone and a slower battery drop.
3. Display & Visuals
Since this phone uses an AMOLED screen, black pixels actually turn off, saving power.
  • Enable Dark Mode: Go to Settings > Display > Dark Mode.
  • Turn off Wallpaper Carousel: This is a known battery hog. Go to Settings > Lock screen > Glance for Mi and turn it OFF.
  • Always-On Display (AOD): If you have this on, set it to "For 10 seconds after tapping" rather than "Always."
4. Optimize HyperOS / MIUI Battery Settings
The built-in battery tool is actually quite effective.
  • Go to Settings > Battery.
  • Check the "Current Mode"—switching to Battery Saver (not Ultra) can give you an extra 2–3 hours of screen time.
  • Look at the list of apps below. If you see an app you rarely use consuming a high percentage, tap it and select "Force stop" or change its Background Settings to "Restrict background activity."
5. Disable "Wake Screen for Notifications"
If your phone is constantly lighting up in your pocket or on your desk, it’s wasting power.
  • Go to Settings > Lock screen.
  • Toggle off "Wake Lock screen for notifications." Use the notification LED or a vibration instead.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Aman Kapoor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 39
Her zaman: 217
