How I can replace transmission oil
How I can check transmission oil level
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@mandeepmaan here are the Atfinstructions for the Ford PowerShift DPS6/6DCT250 which is one of the transmissions used in your Fiesta. Essentially, you open the drain plug to drain the ATF (on a warm transmission only) and use the filler plug to add ATF. You will need to fill until it starts to leak back out of the filler plug.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 4
Son 7 gün: 20
Son 30 gün: 117
Her zaman: 576
@mandeepmaan what exact year and model is your Fiesta and I assume you are referring to an Automatic Transmission?
oldturkey03 tarafından
