Ana içeriğe geç
Nintendo Switch oyun konsolunun, tümleşik Joy-Con kontrolcülerine ve biraz daha küçük bir ekrana sahip, yalnızca elde taşınabilir, daha uygun fiyatlı bir sürümüdür. 20 Eylül 2019'da piyasaya sürülmüştür.
Switch lite screen misaligned
Hi, my switch lite screen is misaligned and looks wonky. How would I go about fixing it? Is it possible to do without opening?
Resim
Resim
Resim
Resim
Bu iyi bir soru mu?
Puan 0
2 Yorum
Hi!
Can you share some pictures with us, as how it looks like? This will help us to identify the issue.
Mevcut bir soruya görsel ekleme
Most likely it's just the screen and yes you most likely do need to open it up.
But we cannot say anything for sure without the photos.
Thank you!
tarafından Paylaş
Images added
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi!
Thank you for the pictures!
As in the last photo it's indeed slightly misaligned.
Since when did this happen?
Anyway, the only way to fix this, is to open it up and check how the screen is sitting in there. If possible, try to align it manually (carefully).
Those screens are incredible fragile, so be careful all the times.
In the worst case, a screen replacement is needed, but I don't think this will be the case.
Guide for how to get there: Nintendo Switch Lite LCD Değişimi
Please let us know how it goes!
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
It is new, I noticed it after I set it up, problem is it's the japanese version so Nintendo won't accept the warranty in UK. I will try to get used to it for now as I know it isn't the worst but if not I will try the repair myself. Thanks for the responses.
tarafından Paylaş
Ah, definitely a factory fault here. Whenever you go back to Japan, you can get it swapped for a new one. I agree, whenever it's completely new, I won't repair it as well. Have a great day!
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Awais Ali sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 27
Son 30 gün: 80
Her zaman: 308
