Air conditioner not.working
After replacing tipm my air conditioner is no longer working. Replace relay, its fully.charged but.still doesnt work
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If the A/C stopped working right after replacing the TIPM, the issue is likely related to power, programming, or communication rather than the refrigerant charge itself.
A few things to check:
Since you already replaced the relay and confirmed the system is charged, I would focus on electrical diagnosis next. A multimeter or scan tool will help much more than replacing more parts randomly.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 226
This question was migrated from https://meta.ifixit.com/Answers.
iRobot tarafından Paylaş
Hi @kathy21141
As you mentioned replacing the tipm, I assume that the air con is in a motor vehicle.
If this is correct, what is the make, model and year of the vehicle?
Moderator.
jayeff tarafından Paylaş
@jayeff 2019 dodge grand caravan
Kathy tarafından Paylaş
@kathy21141
Does the blower motor work when you turn on the air con?
Can you hear the compressor clutch operate when you turn on the air con - with the engine idling there should be a clunk sound as an electric clutch engages the compressor pulley so that the serpentine belt turns the compressor?
