What is causing my controller to act like this?
So for different controller I installed normal sticks and it won't charge or connect to my PC. I noticed on the four prongs on the analog stick that is R3( works in-game and camera spinning) were really short. I still can connect to my ps4 via wireless. I was able to press X to enter the game from the ps4 menu, but in the main menu when I pressed X it wouldn't register. So I removed a solder from that analog stick and then I was able to enter the game from its main menu still not charging nor I can connect to PC I was able to connect prior to replacing sticks.
Bu iyi bir soru mu?
Hi!
Is it possible to sent us pictures from inside the controller? Maybe a trace is damaged.
Thank you!
koppie007 tarafından
Hi, I uploaded the images
Christopher D tarafından
They do not seems to be very damaged (just a little, but should be fine). If you check the most right side, is there a solder blup on the motherboard? Also, can you try to clean with isopropyl alcohol? Thanks!
That could mean that the joystick could be faulty
Could be, would try another one and see how it goes :)
4 tane daha yorum göster
