Ana içeriğe geç
Epson EcoTank L3150 Wi-Fi Çok İşlevli Mürekkep Tanklı Yazıcı
Printer not giving print
Why ja my printer says paper jammed
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@nehashukla the most common issue is that there actually is a piece of paper that is stuck along the paper path. You will need to inspect this carefully. Sometimes a few puffs of canned air cleans out the paper path.
Resim
If there is absolutely no paper that could cause this, the issue maybe related to the PE sensor or the main board. Use the Epson L3150 SM to work on that. You can always trace the PE sensor from the PE connector on the main board. Also, inspect the PE lever spring to make sure that it is all still fully engaged.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
The slightest paper, or dirty roller on the L3150 could activate this error. Perhaps check the paper path very carefully and clean rollers if possible
Puan 0
Yorum Ekle
Yanıtını ekle
Neha Shukla sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 18
Her zaman: 114
