Ana içeriğe geç
17 Eylül 2020 tarihinde piyasaya sürülen orta segment bir Realme telefon. 90Hz yenileme hızına sahip 6,5 inç 720p IPS ekran, Snapdragon 662 işlemci ve 128 GB'a kadar depolama alanı ile gelir. Temel olarak Narzo 20'nin yeniden markalanmış hali olan Avrupa versiyonu ile karıştırılmamalıdır.
How I can repair my software
How i can repair my realme 7 phone's software
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
You'll need to access the Realme site here: software update
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
@sukhjinderkaur that will depend on what is going on with your phone. If it still boots up but lags or freezes or your Apps are crashing you might just need to do a factory reset. If it is stuck in a bootloop (hanging on the realme logo), you will need to do use the stock recovery steps. If it is hard bricked you will need to reflash your phone. For the reflash check on here
To do a factory reset:
  • Turn your phone completely off
  • Press and hold both the Power Button and the Volume Down Button at the exact same time
  • When you see the "realme" logo appear on the screen, let go of the buttons. Look at the bottom left corner of the screen, it should show a message that says "Recovery Mode."
  • On the language selection screen, tap whatever language you are using. You can also use the Volume buttons to highlight your language and the Power button to select it.
  • Next tap on Wipe Data ==> Format Data. A 4 digit code should pop up on the screen. Type that code in, tap Format, and let the phone run its wipe cycle.
Since the OS rebuilds the base directories it will take a couple of minutes (~10min) for the initial screen to show up.
Just remember that a factory reset erases all of your data. That includes your photos, music, contacts Apps etc. You also have to make sure you know the password to the Google account that was used when you first set up your phone. Without that you will not get into your phone since the Android FRP requires this to allow you to use the phone.
Puan 0
Yorum Ekle
Yanıtını ekle
Sukhjinder Kaur sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 114
