Ana içeriğe geç
Beşinci nesil Sony PlayStation 5 DualSense oyun kolu için onarım kılavuzları, sökme işlemleri ve sorun giderme bilgileri. CFI-ZCT1W model numarası ve BDM-050 anakart modeli ile tanımlanır.
Need Help identifying and looking for replacement part
Resim
Hello! this controller was my first attempt at repairing and i accidently touched the plastic socket with the soldering iron. im trying to find the name of the socket on the controller that the trigger ribbon inserts into. i can't tell if it's the same as the microphone socket. Below is a link to aliexpress with a similar looking part to it but just in white and wondering if i can just use that. Thank you in advance!
https://www.aliexpress.us/item/325680918...
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi!
Yes you can use the white one. Color doesn’t matter. The 16 pin one is the one you need.
But first, count the pins on the controller, just to be sure if it really is 16 pin!! Confirm it first.
Also, you can contact the seller and ask for which revisions they are meant.
In short: most likely you need the 16 pin yeah.
Please let us know how it goes!
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Hello! Thanks for responding! Counted the pins and it seems be a 6 pin. Guess V5, Motherboard Model BDM-050M uses a the smaller version instead of the 16 pin. the Part will take some time to arrive. Hopefully it all goes well and i remember to report back. Have a great day!
tarafından
Ah sorry! The V5 is indeed using smaller ones. Hopefully it will arrive soon, so that you can repair it :). Have a great day as well!
tarafından
Yorum Ekle
Yanıtını ekle
Omar G sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 165
