Ana içeriğe geç
PS4 kontrolcüsü, CUH-ZCT1 modeli. Kasım 2013'te Sony Computer Entertainment tarafından piyasaya sürülen, altı eksenli ve 3,7 V lityum iyon bataryalı bu kontrolcünün onarımı oldukça kolaydır. (NOT: Teardown rehberi bu model için DEĞİLDİR)
Why ps4 controller does turn on on
My PS4 and another controller work perfectly fine, so the issue is only with one specific DualShock 4 controller.
Problem details:
When I connect the controller with USB, the orange charging light appears briefly and then turns off. Pressing the PS button does nothing. I charged it for over 24 hours with no change. I already tried resetting the controller using the reset button on the back. The same USB cable and PS4 work correctly with another controller.
Because another controller works normally on the same PS4, I think the issue is inside this controller itself.
Does this sound more like:
a dead battery, faulty charging board/USB port, or motherboard failure?
Bu iyi bir soru mu?
Puan 0
2 Yorum
When you have the charger on it, and press the PS button, nothing happens as well? Or does it work when plugged in? If yes, replace the battery. Otherwise you need to check the membrane. Is it a Power A controller or genuine Dualshock 4? Thank you.
tarafından Paylaş
@dan0 when I plugged in nothing happens and it is dualshock 4
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi!
Thank you for your comment.
First: replace the battery and see if that solves it.
Guide: DualShock 4 (CUH-ZCT1U) Batarya Değişimi
If not, you most likely need to check the membrane. But first of all, replace the battery and see what happens!
Guide for the membrane circuit: DualShock 4 (CUH-ZCT1U) Düğme Devre Membranı Değişimi
Thanks!
DualShock 4 Batarya Görseli
Kılavuz
Zorluk:
Orta
15 - 30 minutes
DualShock 4 Düğme Devre Membranı Görseli
Kılavuz
Zorluk:
Orta
1 - 2 hours
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
ASIF Iqbal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 8
Son 30 gün: 30
Her zaman: 189
