Ana içeriğe geç
Kasım 1998'de piyasaya sürüldü, HKT-3020 model numarasıyla tanımlanır.
What is going on here?
Hi, I recently install the retro gem for my Dreamcast and when I boot the system it doesn't show the boot animation for the system only when its completed I went to debug menu and have hearts on all my installs as well as updated the firmware. I tried this on two TVs and it does the same thing. I have a Gamecube with a plug-in mini-HD to HD and it does something similar I used the same cable from that.
Bu iyi bir soru mu?
Puan 0
8 Yorum
Hi!
Is it possible to upload some pictures regarding the issue you are facing?
Mevcut bir soruya görsel ekleme
Thank you.
tarafından
Can I upload video? pictures won't help
tarafından
Yes you can!
Using Media
Thank you
tarafından
Hi, I upload the videos in the first video it's the gamecube with the hdmi plug-in, the second one is the gamecube with S-video, and the third one is the dreamcast with the mini-HD to HD. I used the mini-HD to HD from the plug-in I couldn't get the av footage for the dreamcast cause I think I messed something up ....again, but it does the same thing as the gamecube plug-in. I hope its just the mini-HD to HD cable that's causing this. It's the basic edition of pixelfx mod
tarafından
Okay, replacing the cable you can try indeed. It does not really look like a hardware issue in the first 2 pictures. More firmware related. Which firmware has been installed? Thanks!
tarafından
3 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@dan0 Hi, I went on the retro gem discord and I was told that the delay in video is normal because the retro gem is booting.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
Alright. Then it is normal behaviour. Thanks for sharing!
tarafından
Sorry for the delay thank you
tarafından
No problem at all! Have a great day :)!
tarafından
Yorum Ekle
Yanıtını ekle
Christopher D sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 24
Son 30 gün: 34
Her zaman: 213
