Ana içeriğe geç
Samsung, Galaxy S23 serisini 1 Şubat 2023 tarihinde gerçekleştirdiği "Unpacked" etkinliğinde duyurdu. Yeni Galaxy Book3 ve Galaxy Book3 Pro dizüstü bilgisayar serileri de yine aynı etkinlikte tanıtıldı.
Phone is stuck in boot loop
My phone was stuck in boot loop for a good day or so and I left it alone, now it won't even wake up. I left it on the charger for a day and still nothing. I just want the photos off of it. Is there a way I can do this myself or do I have to take it somewhere?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
This can happen if an update is incomplete or was somehow interrupted during the update. This is not always an easy repair, but your phone hardware itself should be fine. If you are techie enough you could connect to a USB powered hub and try to boot through an external monitor. If that doesn't work you could do a hard reset, instructions for which can be found online. You can try holding down the volume key and the power button for approximately 28 to 30 seconds. Release it, and then try to power up normally and see what happens. Good luck
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Stephanie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 38
Her zaman: 148
