Ana içeriğe geç
Nisan 2022'de piyasaya sürülen bu 5G destekli Moto G, 1080 x 2460 piksel çözünürlüğe sahip 6,8 inç 120Hz LCD ekran, Qualcomm Snapdragon 695 yonga seti ve 50 MP geniş açılı, ultra geniş açılı ve derinlik kameralarına sahiptir. Model XT2215.
Volume keypad not working
Even pressed the vole button not worling
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@neilnavarrete if your volume does not work with the slider and the buttons then the issue could be a settings issue. First you want to make sure that you do not have the “Do Not Disturb” on, then you want to disconnect any hidden Bluetooth devices.
Next I would reset the audio settings: Go to Settings ==> Sound & vibration ==> Moto Audio and tap Reset to return all audio preferences to default.
If it still does nto work you want to try and boot your phone into Safe mode. Hold the Power button until the "Power off" prompt appears, then touch and hold the "Power off "on the screen to reboot in Safe Mode. If your volume works in Safe Mode then you know that a downloaded third-party app is causing the issue. You will have to remove your third party apps.
Anything past that would most likely be an issue with the audio circuit on your main board.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Neil Navarrete sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 69
Her zaman: 253
