Flashers randomly coming on
Hazard light are randomly coming on when parked. This then drains the battery.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Randomly activating flashers are usually caused by a faulty turn signal switch, hazard switch, or a wiring short. Start by checking for loose/corroded connectors and inspect the flasher relay. If the problem occurs when hitting bumps or turning the steering wheel, the switch or wiring is the most likely culprit.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 50
Her zaman: 196
