Don't use your AC plug. Since the controller is meant to be plugged into the PC power supply, which only carries 5V DC and 12V DC over the molex connector, it would surely be destroyed by the AC power. You would have to try to find that voltage on the XBox. I know it does have it, and I am currently looking at the schematic for a "possible" hookup. Also, you did not tell us what is wrong with your XBox and the fan controller may not "get my Xbox back up and running again" depending on what is wrong with it.
Just posted an image about the pinout of the plug to your XBox. You may consider to tap into that for your fan controller.
Here is how to connect the Touch2000 to the motherboard.
Here you can see that it needs 5Volts as well as 12volts. From the way I read it, it controls your fans, by plugging your system fans into the Touch2000 and max power per fan channel is 6 Watts (0.5A@12V). That means you would also have to make sure that the fan of your XBox would fit those connectors. I am not saying it is not possible, but will require a lot of headwork before doing it. A great mod opportunity :-)
Here you can see the voltage on the Molex connector. They are the same colors as the ones on the connector from your Aerocool. With the power points shown on the XBox you could now make a connection to the power connector. It does show you where to connect the 12V, 5V, and ground.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
2
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
