Ana içeriğe geç
JBL 760NC olarak da bilinen JBL Tune 760NC kulaklıklar, net ses için Aktif Gürültü Engelleme teknolojisine sahip kablosuz kulaklıklardır. Hafif, katlanabilir yapısıyla uzun süreli dinleme seansları için harikadır.
Why its Microphone not working
I can hear through my headphones, but my microphone isn't working, so I can't input sound. I'm only receiving audio output, with no microphone functionality.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi!
This can be caused by multiple issues.
First of, make sure that your microphone volume, or call microphone volume, on your device is neither muted or set too low, if you have such settings available. Also check that the app you're trying to use the headset with has sufficient permissions for microphone, Bluetooth and the like.
Otherwise, make sure you have sufficient Bluetooth device permissions for your headset. How to check this differs per device, but can typically be found by:
  • Entering Bluetooth devices / Paired devices menu.
  • Find and select the headset (or press more info).
  • Then check if you have allowed any available options, and do allow any and all options available, such as Phone calls, Media Audio, Contact Sharing, e.t.c.
Else, try to unpair or "forget" the headset, then re-pair the headset.
Make sure you're having the latest firmware / devices drivers.
Is there a companion app? If there is, check around in the settings for microphone settings or anything of the like.
Try out the headset on another device to discern if it is the microphones/headset that is broken, or if it is a software issue.
Another common technique is to fully discharge the headset (typically by using it until it turns off), and then charging it back to full battery again.
All these tips above are assuming that the microphones works. Have you recently dropped the headset, or gotten it drenched in water? Please respond and we'll see how we can assist you further.
Good luck,
Cheers
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Nitin verma sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 35
Son 30 gün: 99
Her zaman: 261
