How to remove pink lines from screen
My laptop screen has some pink horizontal lines at the bottom. How can I fix this?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Ouch! Lines tend to be a damaged LCD panel. You'll likely need a new display to fix it. To be sure connect your laptop to an external display if the image there is the same with pink lines that you have a logic board issue otherwise you've proved the disp,ay is damaged.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 63
