Ana içeriğe geç
Model numarası itel A665L olarak tanımlanan itel A70 Android akıllı telefon için onarım, söküm ve sorun giderme bilgileri.
moving and scrolling by itself
sometimes, my fone moves/ scroll by itself without me doing it, why?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You're experiencing the phenomenon known as "ghost touch". There is electrical noise on the signal lines that carry the digitizer information from the touch screen to the processor, and that noise is getting interpreted as screen touches. Usually it's due to damage to the delicate connections between the flex cable and the glass the touch screen circuits are printed on. Unfortunately, separation or damage like that isn't repairable, so the only real fix is to replace the screen. Since the digitizer and display are fused together into a single assembly, you'll be replacing both at the same time.
This video will show you how to go about replacing your screen.
ITEL A70 - LCD SCREEN REPLACEMENT - CHANGE DISPLAY - YouTube
Although they're using a hot air gun to heat the front and back of the phone to soften the adhesive, an ordinary hair dryer will work for you; it just takes a bit longer to heat up the glue. Be careful to clean off all the old glue by scraping it off or using some 90% or higher concentration of isopropyl (rubbing) alcohol to wipe it with cotton swabs.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Thomas Belles sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 37
Her zaman: 148
