Ana içeriğe geç
Help, my controller doesn't stay connected wired
My Xbox Series X controller (Model #1914) seems to have a loose usb c connection since whenever I connect it via a wire it ends up disconnecting a lot. However, when I manage to get it charged (again cuz of the poor wired connection) and connect it to my pc via Bluetooth it works flawlessly.
How could I reasonably fix this issue without soldering if possible?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi!
Just asking (probably you already tried it): Did you tried another USB-C cable? Would do that first.
If yes and the issue continues, it's most likely the USB-C port... The downside is, that it need to be replaced and this requires soldering...
You could replace the board completely, but this will be more expensive.
Otherwise I advise to contact a local repair shop to do it for you.
Please let us know how it goes!
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Hello! quick update, ive tried it again but now the controller itself refuses to hold a charge (using the xbox plug and play kit) but stays connected wired sometimes
update on my update i pulled up the positive and negative terminals to tighten the connection up and it now holds a charge and when i used a new cable it seems to have made it work?? although it could be a fluke since ive tried multiple cables before.
ill probably just replace the entire board with the usb c connection anyways by buying a used controller.
tarafından
That is a good option as well!
Replace the board from the replacement controller. It could be battery pins related.. but those are also installed on the same board.
Please let us know how it goes :)!
tarafından
Yorum Ekle
Yanıtını ekle
saviourr sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 51
Her zaman: 203
