Need help identifying an integrated circuit
Hello,
I have a TP-Link Archer C7 router (TL-WDR7500 Ver: 6.0) which needs integrated circuit marked U25 to be replaced. However, it cracked in half and there is no way to see the markings.
Would kindly appreciate for any information regarding this component.
Thank you.
Adding images (Don't pay attention to the capacitors :D ):
1. Mainboard:
2. Damaged part (should be some kind of power filter):
Bu iyi bir soru mu?
Have you got a photo of the circuit board and the cracked component? Sometimes you can figure out what the IC does if you know where it is is on the board.
honakrisi tarafından
Hi!
To make it easier for us to help you please upload an image of your pcb and of which component it is that you're looking for.
You can follow this guide to update your question with an image: Mevcut bir soruya görsel ekleme
Good luck,
cheers
MeekVixen tarafından
