Chrysler 300; Chrysler tarafından üretilen ve pazarlanan, dört kapılı sedan ve station wagon gövde tiplerine sahip, arkadan itişli, önden motorlu, tam boy lüks bir otomobildir.
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
2 Yorum:
@testemail what makes you think that you have an issue with your ABS unit? Have you got your vehicle scanned? Any error codes? What are the issues with you brakes? What exact year is your 300?
In addition to oldturkey03's question, if the abs indicator turned on and remained on, there's an error code but decoded by readers/scantools Autozone, Advanced Auto, transmission, collision and repair shops have. Not generic low cost readers. If the abs indicator cycles on and off with other indicators when turning on ignition, abs is operating correctly (power on self tests including all wiring to wheel speed sensors). Abs errors are usually C type codes.
oldturkey03 tarafından Paylaş
F Dryer tarafından Paylaş
