Ana içeriğe geç
iPhone is stuck in a reboot loop
iPhone is stuck in a reboot loop after the software update.
What should I do?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum:
is it restarting after 3 minutes or simply not booting into the os and instead flashing the apple sign?
tarafından
Also what version of iOS are you on?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
If the reboot loop started immediately after the update, try forcing a restart first. If that doesn't help, connect the iPhone to a computer and attempt an update or restore using Recovery Mode.
If the restore fails with an error (such as 4013 or 4014), or the phone continues rebooting afterward, it's likely a hardware issue rather than the software update itself.
If you can access the analytics logs, run an iPhone panic log analysis. The panic log can often identify the hardware component responsible for the restart loop before you start replacing parts.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
ben levi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 33
Her zaman: 33
