Ana içeriğe geç
Nintendo Switch oyun konsolunun, tümleşik Joy-Con kontrolcülerine ve biraz daha küçük bir ekrana sahip, yalnızca elde taşınabilir, daha uygun fiyatlı bir sürümüdür. 20 Eylül 2019'da piyasaya sürülmüştür.
My switch lite wont recognize button presses
So i just did a full shell mod and screen replacement on my switch lite and ever since I have these problems with the buttons,thumbsticks, and touchscreen not registering my presses and movements I replaced the ribbon cable to the right daughter board thinking it was the problem and I have seated and reseated all of the ribbon cables, put two different pairs of joysticks. And its really hit and miss as to when it does it but it wont let me do multiple presses making it to where I cant unlock my device. Does anyone have any ideas what I should do I have all the electronics repair tools needed to fix most things
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi!
Could be a lot of things. Since you have replaced the screen, it could be that the touchscreen was damaged and not registering your input. I would check that one out and also the ribbon cable, in the worst case, you need to replace it for a new one.
I know that there are some really bad shells out there, so it's possible that the shell squished something on the motherboard or broke ribbon cables. Can you let us know which brand you are using? Or is it something from AliExpress?
Are all the buttons stopped working? If yes, it could be motherboard related...
In my opinion, I would transfer it back to the old shell and test again to see if that will work. OR if it's too damaged, buy a broken/donor Switch Lite and get the shell from that one.
Adding pictures could help us > Mevcut bir soruya görsel ekleme
Thanks in advance!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Andrew Derosa sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 41
