Ana içeriğe geç
Apple'ın hücresel bağlantı seçeneğine sahip altıncı nesil akıllı saati, 18 Eylül 2020'de piyasaya sürüldü. Model A2376, 44 mm.
Reattaching screen after battery replacement
I just replaced the battery in my Apple Watch 44mm Series 6. The battery replacement went fine but I am struggling to reattach the screen. I purchased the Screen Adhesive along with my new battery but the adhesive I received was worthless - I didn't stick anywhere. I tried using E6000, which the repair guide recommended as an alternative but it doesn't feel as though the screen is securely attached. Does the screen snap in at all, or is it just the tape/glue that holds it in place? Any recommendations for securely reattaching the screen will be appreciated.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hello,
It is only the adhesives that hold the screen in place. If you don't adhesive the screen down a lot, then the screen will come off, and you will loose all of your water resistance.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Thank you. I'll try again.
tarafından Paylaş
@jimstone You'll need to apply pressure after the screen is adhered on otherwise the bond would not be strong enough and it'll fall off after a few days(I learnt the hard way)
tarafından Paylaş
Thanks. It is sitting with a spring clamp on it right now!
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
James Stone sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 57
Her zaman: 146
