Ana içeriğe geç
Skullcandy Air Raid, 15 Kasım 2013 tarihinde piyasaya sürülen ve Bluetooth özellikli herhangi bir cihazdan müzik akışı sağlayan kablosuz taşınabilir bir Bluetooth hoparlördür.
Rained on while charging
I was charging it outside and it rained lightly for maybe 30 minutes or so and now the speaker won't turn on at all how can I fix itI was charging it outside and it rained lightly for maybe 30 minutes or so and now the speaker won't turn on at all how can I fix it
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Rain can short circuit electronics, starting with water entry into the charging port. Whether this caused the battery to drain is one possible issue. Disassembly should be performed to wipe off remaining water, allow inspection of wiring for corrosion and damage to electronics. Tissues, cotton swabs and isopropyl alcohol can help with clean up. If you are successful in disassembly, leave parts exposed to dry out. Placed in a tray on top of a gas stove with its pilot light supplying gentle heat, in a gas oven with similar pilot light for heat or out in the sun. Warmth over several hours will help evaporate remaining moisture. Reassemble and try recharging. The battery may recharge and allow operation. Battery specs are printed on labeling. Click on the Guides tab in the upper right to open a new page and click on Battery Replacement to reveal disassembly procedures or below. Skullcandy Air Raid Pil Değişimi. Hopefully, damage didn't occur, the battery recharges, and you restored your Skullcandy Air Raid back to full function.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Carlos Cordova sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 33
Her zaman: 88
