Allwinner H618 custom board
- (BA882_141_V1.0) flashing fails at 44% with error 0x161
Body: I am trying to flash a custom Allwinner H618 Android TV box / embedded board (Model: BA882_141_V1.0 22244) from a defunct manufacturer, and I don't have the original backup firmware.
Details:
- SoC: Allwinner H618
- RAM Chips: 4x
4EE77 D9QBQ(batch codes vary slightly: HFB7, H8JP, HHTC) - Symptom: Every compatible firmware I've tried stops flashing at around 44%–45% and throws error
0x161(Download Boot Failed). The front display doesn't light up, and only the optical port LED stays on. - What I've tried: Tested multiple generic firmwares matching the hardware, but they all fail at the bootloader/DRAM initialization stage due to missing custom boot parameters.
Is there a known workaround, or a way to build/modify a compatible bootloader or DRAM configuration to bypass this error without the original factory
Bu iyi bir soru mu?
