Ana içeriğe geç
Samsung, Galaxy S23 serisini 1 Şubat 2023 tarihinde gerçekleştirdiği "Unpacked" etkinliğinde duyurdu. Yeni Galaxy Book3 ve Galaxy Book3 Pro dizüstü bilgisayar serileri de yine aynı etkinlikte tanıtıldı.
Broken battery pull tab; Safe ways to pry out battery?
​I tried replacing the battery using the iFixit kit (without isopropyl alcohol). Whilst trying to pull out the old battery, the blue pull tab snapped, and I’m a bit hesitant to use a prying tool.
​I’ve closed everything back up for now and will buy a bottle of isopropyl alcohol.
​Could I get some tips on prying out the battery safely without damaging it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @keralite
I find the best way to do this is to apply a line of Isopropyl Alcohol 99%+ along one side edge and the bottom edge of the battery, using an 18G blunt tip dispensing syringe,¹ allow the alcohol a few minutes to soften the adhesive and then gently, use a pry tool to lift the battery up a small bit.
Then apply some more alcohol under the slightly raised edge of the battery, wait for the adhesive to soften a bit and then pry the battery up further and so on until it is completely removed from the case.
Notes:
¹ Examples only. You could always ask your local pharmacist if they have anything suitable that you could use. Just explain what you want to do with it ;-)
Do not attempt to remove the battery all at once. Raise it a bit at a time.
Do not use a metal pry tool as you may easily puncture the battery. Old credit cards or guitar picks can work if you don't have a plastic spudger.
Remember to disconnect the battery cable from the systemboard before commencing the removal procedure and to dispose of the old battery responsibly at a hazardous waste collection point in your location.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Abhishek K sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 65
Her zaman: 146
