Earbuds case charging problem
My earbuds case not not charging and it is full dead
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi!
If your earbud case is not charging, start by testing another charging cable and another charging adapter to make sure it is the case that is the problem. Check the charging port for any debris or corrosion and if found clean the port. Also check if the charging port in the case is loose, if the port is loose, you may need to replace the port.
Assuming the prior things are all okay, then this is most likely a dead battery or the battery cables has gotten loose. Dead batteries are common, as batteries age and break down by time and usage.
To check and replace battery in the charging case, you will need a few basic tools, and a soldering iron. iFixit does not have a guide to replace the battery in the case, but I found a Youtube video guide for it, how to open the case starts at 6:50. The video is in Hindi, but the process is pretty self-explanatory.
Some additional notes on the video guide:
Take lots of pictures while you work. Once you're done, upload those pictures and create a guide, this will help the next person who has the same issue.
Please respond if you have any further questions.
Good Luck,
Cheers
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 65
Her zaman: 170
3 Yorum
Rechargeable batteries are not forever. They have a finite life of several years if used often. Unfortunately, they're sealed. Not repairable unless taking risks to open the charging case to determine battery size and replacement. Since there are three batteries, when one fails, the others may fail. Opening ear buds charging case may damage internal parts. You can try finding a repair shop, try opening yourself and then determining battery replacement from many online sources, or buy a new set of ear buds.
F Dryer tarafından Paylaş
Boult earbuds not working
Sanu Kumar Chouhan tarafından Paylaş
@sanukumarc64514 did you read my previous reply?
