Ana içeriğe geç
Fujitsu Lifebook E753, 2013 yılında 15,6 inçlik bir iş dizüstü bilgisayarı olarak piyasaya sürülmüştür. Gücünü 3. Nesil Intel Core (Ivy Bridge) işlemcilerden alır. 16 GB'a kadar DDR3 RAM desteği sunar, özel sayı tuş takımlı tam boyutlu bir klavyeye sahiptir ve yaklaşık 2,1 kg ağırlığındadır. Standart 6 hücreli bataryası (63 Wh veya 72 Wh seçenekleriyle) yaklaşık 12 saatlik çalışma süresi sağlar. E753, ikincil bir 28 Wh bataryayı kabul edebilen modüler bir yuvaya sahiptir. Her iki batarya da kullanıldığında, dizüstü bilgisayar 18 ila 21 saate kadar toplam pil kullanım süresine ulaşabilir.
Laptop not Powering On
After not charging my laptop for a long while due to Power Outage, When the Power supply was restored, I tried charging it and after charging, It did not switch on. I've tried putting it on AC mode - Plugging it without the battery installed - and it still didn't work.
Please what should I do
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@ujuakuokafor first you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Use something like this video to open your laptop up. Post Some good pictures of what your motherboard looks like with your question. That way we can see what you see. Mevcut bir soruya görsel ekleme
Your computer most likely does have a Fujitsu 621881-X1 motherboard and I have not been able to find the schematics for this. You will need to depend on your own troubleshooting skills if the error is with the motherboard.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thanks, I'll try opening my Motherboard, snap the picture and send it back
tarafından
Yorum Ekle
Yanıtını ekle
Ujuaku Okafor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 24
Her zaman: 59
