Ana içeriğe geç
22 Eylül 2023 tarihinde piyasaya sürülen, Apple'ın en üst düzey amiral gemisi akıllı telefonu iPhone 15 Pro Max için onarım, sökme ve sorun giderme bilgileri. 6,7 inç ProMotion OLED ekran, yeni 5x optik yakınlaştırmalı periskop lense sahip üçlü arka kamera sistemi ve 5G desteği ile gelir. iPhone 14 Pro Max'in halefidir.
iPhone 15 Pro Max Unresponsive
I have an iPhone 15 Pro Max that has endured a fall.
The phone was in a case, and was dropped directly on one of its corners.
Neither the front or back glass appears to be damaged in any way, yet the screen will not turn on and it does not chime when it is plugged into power.
I have tried putting it into recovery mode while connected to my Mac, and it appears to successfully update, but never shows up in the sidebar and the device still does not appear responsive.
I currently do not have the tools necessary to open it myself to test the display cable connection, but I am hoping this is the issue and that this won't be a micro-soldering job.
I do not have Apple Care on the device, and A**le quoted me $850 to repair it.
Any suggestions? Anyone with a similar experience?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
A corner impact with no visible glass damage can still knock the display connector loose or damage the display/board circuitry. Since the Mac isn’t detecting it properly either, I wouldn’t assume it’s just the screen yet.
I’d have a repair shop open it and test with a known-good display and inspect the connectors before paying Apple’s $850 quote. If it was able to update but still won’t boot/display, an iPhone panic log analysis could also help if you can retrieve a panic log.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Roach sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 35
Son 30 gün: 77
Her zaman: 130
