Ana içeriğe geç
Profesyonel ses ekipmanları; kayıt stüdyoları, canlı ses güçlendirme, yayıncılık ve diğer birçok uygulama dahil olmak üzere profesyonel ortamlarda kullanılmak üzere tasarlanmış yüksek kaliteli ses cihazlarını ve sistemlerini ifade eder.
Do you fix QSC Power amps?
I have a 4 channel QSC pld 4.5 and there Is only buzzing noises coming from each channel
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Hi, @warrenreed96485
We don't, but you can! Try to find a guide and the tools to fix your problem, or try to unplug and replug in the connection for the speakers! That worked for me!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@warrenreed96485 iFixit doesn’t actually fix things for people. The site is a place for people to learn repair for themselves—the “i” in iFixit is you! For this repair, I’d start by checking Switch Mode Power Supply (SMPS). Reason for is that you have buzzing on all channels which is typically an error with an external ground loop from the input source or teh SMPS.
See if we can narrow it down. Disconnect all the input cables from the amplifier, leave only the speaker outputs and the AC power cable connected. Turn the amp on. If the buzzing completely stops, the amp is functioning normally, and the noise is an issue with an upstream mixer, a damaged audio cable, or a ground loop between your equipment racks.
If the amp still buzzes with nothing connected to the inputs, unplug it and connect it to a complete different outlet/circuit. Faulty dimmer switches, fluorescent lighting, or other failing electrical equipment on the same circuit phase can directly cause a hum into the amps power cord.
If the buzzing persists on a clean circuit with isolated inputs, the SMPS is failing to filter the power. For that you would have to check all the caps on the SMPS to see if those are actually still filtering. Remember to discharge all the caps after you disconnect the power from the SMPS. Those hold a charge reasonably long and can zap you pretty good if not discharged.
Let's see if we find some schematic for this amp to help you further.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Warren Reed sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 41
Her zaman: 41
