Ana içeriğe geç
Lenovo IdeaPad 3/3i 15ITL6, Intel 11. nesil platformunu temel alan 15 inçlik bir IdeaPad 3 modelidir. Farklı CPU, RAM ve SSD yapılandırmalarına sahip çok sayıda model olsa da, bunların onarımı temel olarak aynı görünmektedir. 2020 yılında piyasaya sürülmüştür.
Charger light on and off
When it's connected with the charger, the charger lamb next to DC - lights red for about 10 seconds and disappear and repeats the same cycle over and over but the battery wouldn't be charge and laptop doesn't work, what to do next?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
This could be a depleted battery or bad battery - try simple things first - unplug charger and press and hold the power button for >30 seconds. then plug in charger, any change in the light? If so, note the blink code pattern for further diags. If not it could be indicating a bad battery or just severely depleted - leave on charger for >2 hrs without trying to turn it on.
Try to turn it on - anything?
Next I would open it up and disconnect the battery (manual may help: https://download.lenovo.com/consumer/mob... ), then press and hold the power button for 30 seconds, then plug in charger and turn on - ? If it now turns on, its likely a bad battery that needs replacing.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
@muhammmadsamir this "lights red for about 10 seconds and disappear and repeats the same cycle over and over" means your power supply is attempting to power up your laptop but it can't communicate with the laptop. Try this. Disconnect the AC adapter and remove the bottom cover and completely disconnect the main battery from the motherboard. Plug the AC adapter back in. If the laptop powers on normally, the battery has a dead internal cell or a faulty management board and must be replaced.
If the same issue continues even with the battery disconnected, the issue is with the motherboard. The system is sensing an overcurrent situation on the main power rail right after the initial power handshake. You would need to check the components around the charging circuits for short to ground etc.
To assist you further with that we would need to know what motherboard model is in your computer. It will be printed on your board. It is possible that it is on the top side, so you would have to remove the motherboard to find that number. To work on your computer use the IdeaPad 3i IdeaPad Slim 3 Hardware Maintenance Manual
Post some well focused pictures of your motherboard with your question. That way we can see what you see Mevcut bir soruya görsel ekleme
One more thing you want to check, is your AC adapter. Check the voltage and if you have an ammeter see what it delivers when it try's to turn on your laptop.
Puan 0
Yorum Ekle
Yanıtını ekle
Muhammmad Samir sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 23
Son 30 gün: 46
Her zaman: 46
