Ana içeriğe geç
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Display too bright, even with brightness set to minimum
My iMac display is too bright even with "minimal" brightness (set with F1). If I choose maximum bright the brightness could burn anything that gets close to the display. My wife has another iMac and that does not happen in her mac.
What part should I change? Thanks in advance.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You display is lightened by two backlights (fluorescent lamps) located at the top and the base of the screen. The backlights are driven by an inverter board who receive the electrical power from the logic board. I'm not a iMac specialist and maybe someone here could post the right answer but I think that the inverter board might send too much power to the backlights resulting in an over lightning issue. IMO the logic board or the inverter board is the culprit. You should bring the iMac to an Apple Store and ask a genius to look at it,
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Alfonso Mateos sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 997
