Ana içeriğe geç
The eighth generation of the Mitsubishi Lancer.
Change power steering fluid
How to flush and bleeding power steering fluid in 2003 Lancer?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
David, here is what the manual says:
"FLUID REPLACEMENT
1. Raise and support the front wheels.
2. Disconnect the return hose connection.
3. Connect a vinyl hose to the return hose, and drain the fluid into a container.
CAUTION
Be careful not to position the high-tension cable near the fuel rail.
4. Disconnect the high-tension cable.
5. While operating the starter motor intermittently, turn the steering wheel all the way to the left and right several times to drain all of the fluid.
6. Connect the return hose securely, and then secure with the clip.
7. Fill the oil reservoir with GENUINE MITSUBISHI POWER STEERING FLUID up to the lower position of the filler, and then bleed the air.
POWER STEERING SYSTEM AIR BLEEDING
Perform air bleeding procedure as necessary after replacing the steering gear box or the steering fluid lines.
2. Disconnect the high-tension cable. Turn the steering wheel
all the way to the left and right five or six times while using the starter motor to crank the engine intermittently several times (for 15 to 20 seconds).
CAUTION
• Be careful not to place the high-tension cable near the fuel rail.
• Perform air bleeding only while cranking the engine. If air bleeding is performed while the engine is running, air could enter the fluid. During air bleeding, refill the steering fluid supply so that the level never falls below the lower mark on the dipstick.
3. Connect the high-tension cable. Start the engine (idling).
4. Turn the steering wheel to the left and right until there are no air bubbles in the oil reservoir.
5. Confirm that the fluid is not milky, and that the level is between the high and low dipstick marks.
6. Confirm that there is very little change in the fluid level when
the steering wheel is turned left and right.
7. Confirm that the change in the fluid level is no more than 5 mm (0.2 inch) when the engine is stopped and when it is running. If the fluid level rises suddenly after the engine is stopped, the air has not been completely bled. If air bleeding is not complete, there will be abnormal noises from the pump and the flow-control valve, and this condition could cause reduce the life of the power steering components.
8. If the change of the fluid level is 5 mm (0.2 inch) or more, the
air has not been completely bled from the system. The air bleeding procedure must be repeated."
Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
David sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 7,345
