Ana içeriğe geç
Nintendo Switch 2 Joy-Con 2 kontrolcüleri için onarım rehberleri, söküm ve sorun giderme bilgileri.
ZL Button Spring not working
I am trying to reassemble the left Joycon 2, and when I want to attach the ZL button, it feels like the spring is not doing its work. The ZL button is really steady and almost rubbing the button, so with a little touch it will press it.
Resim
Resim
Update (09/28/26)
Hello,
I was changing the covers. At the end I found the issue. The flex was not seating well on the support. From the top it looked like it was in the support, but I saw it sideways and it was not. This is why the ZL button was almost touching the button.
Resim
Resim
Thank you for reaching out!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
Hi!
Glad that you figured it out :)! Have a great day!
tarafından Paylaş
Thank you! I was about to just accept I busted my controller until I found this.
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi!
Please follow this to step 13: Joy-Con 2 (Sol) Joystick Değişimi
Could you show us how the spring look like?
What is the reason you opened it? Is another shell used or is this a cover that you have put on?
I know that some shells do not fit completely and could cause this as well.
Thanks!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
David Sandoval Galiana sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 101
Her zaman: 163
