Ana içeriğe geç
Makita XDT08, profesyonel kullanım için tasarlanmış, fırçasız motoru ve 18V LXT Lityum-İyon bataryalarla uyumluluğu ile öne çıkan kablosuz bir darbeli vidalamadır. 5-7/8" x 3-1/4" x 9-1/8" boyutlarına ve 1/4" altıgen uç girişine sahip bu alet, çeşitli sabitleme ve vidalama işleri için yüksek tork ve hız sağlar.
cracking the driver case
I need to replace the switch. I have all of the screws out but the yellow plastic peice at the bottom is preventing me from cracking the case open. I have pryed on it with a screw driver and it won't separate. I don't want to break it. How do I split this open without damage.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Yeah, I wouldn’t keep hammering that yellow piece with a screwdriver. On the XDT08, the housing is held together by eight 3×16 screws, and the parts diagram shows the housing as a two-piece housing set. The switch itself is part 650689-0.
That yellow piece you’re seeing at the bottom is probably the battery terminal/support area catching on the housing. When you separate the halves, work around the housing seam with a thin plastic pry tool and gently work the halves apart rather than prying directly against the yellow plastic. The same basic Makita housing procedure on these impact drivers is to separate the two shell halves carefully while keeping the yellow battery-terminal piece seated in the lower housing. Once you get a small gap, go around the perimeter and release the shell little by little. Don't force one spot. There may also be wiring and the controller sitting in the housing, so I'd rather spend five minutes working the seam than crack a $30-ish housing or pull a wire loose.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Brian Taylor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 46
Her zaman: 80
