Ana içeriğe geç
2004-2008 F-150 kamyonet, F-150 serisinin yeniden tasarlanmış on birinci nesli olarak 2004 model yılı için Ocak 2003'te tanıtıldı. 2006 model yılı için F-150 serisine birçok iyileştirme eklendi.
Fuel gauge reading empty
After filling, gas tank fuel gauge reading empty
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@naomigrant let's make sure the gauge itself on the dashboard isn't broken. Try this:
Press and hold the trip reset button on your instrument cluster, turn the ignition key to the "On" position without starting the engine, and wait for "TEST" to appear on the odometer. Let go of the button. All the needles should sweep all the way up and back down. If the fuel needle sweeps smoothly, your dashboard is fine. If not you know you have an issue with the fuel gauge itself.
After that it most likely is an issue with the fuel sending unit inside the tank. To work on that you will need to drop the tank. Here are the files from the SM that deal with that 2006 F 150 Mark LT Fuel Pump Module2006 F 150 Fuel Level Sensor2006 F 150 Fuel Tank Filler Pipe2006 F 150 Fuel Tank
Let us know what you find out.
While you work on your F-150, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person who has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I’d start with the fuel level sender in the tank. If the gauge stays on empty even after filling up, the sender may be stuck or the wiring/connector could be bad.
You can also check the fuse and the connector at the tank, but on these trucks the sender is a pretty common suspect. If the gauge suddenly dropped to empty, I’d look there first.
Puan 0
Yorum Ekle
Yanıtını ekle
naomi grant sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 48
Her zaman: 76
