Ana içeriğe geç
Şu anda Briggs & Stratton şirketine ait olan Murray markası altındaki bahçe traktörleri için onarım rehberleri ve destek.
How do I level the cutting deck?
My Murray Select Riding Lawn Mower 13.5 hp 40" inch is cutting lower on one side than the other. I have tried to level the deck but to avail?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
There should be an adjustment link on one side which will allow you to raise/lower that side to even it with the other side.
Also check to see if you have a bent blade on one side that is cutting in an un-level manner. Rocks and other debris can easily bend a blade.
BILL
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
On some Murray models there is a flap on the fender below the no.1 position on the deck adjustment handle. Put the mower on a level flat surface. Then lower the deck lever down (the deck level point under the flap)all the way, it should be sitting on the ground. Now on the rear of the deck should be some plastic butterfly nuts, loosen those to allow the hanging adjustment arms to move it should level its self out if the arms are not in a bind or rusted up to bad. Then you tighten the butterfly nuts back up take the deck out of the leveling position, then raise to the height you want then try out the mower to make sure if leveled out out.
Puan 1
Yorum Ekle
I own a 46" deck Murry rider and can't level the deck. The left side front of the deck is extremely low compared to the rest of the deck. I can't figure out how adjust the deck properly, need ideas pls.
Puan 0
Yorum Ekle
On it says to remove level or bolt before adjusting height of deck. Where is this bolt and how to adj
Puan 0
Yorum Ekle
Yanıtını ekle
Buddy T sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 13,700
