Ana içeriğe geç
Sony VAIO Fit 14 (2013 çıkışlı), günlük kullanım için tasarlanmış dokunmatik ekranlı bir dizüstü bilgisayardır. 14 inç ekrana, taşıma kolaylığı sağlayan ince bir yapıya sahiptir ve birçok renk seçeneğiyle sunulmuştur. (Üretici Parça Numarası (MPN): SVF14AC1QL)
It is not working
I was playing Minecraft on itt it heated and stoped working
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Work down this ladder and stop at the first rung that changes anything - that rung tells you which subsystem died.
1. Cool it down fully (30 min unplugged), then hard reset. The SVF14AC1QL has a removable battery (VGP-BPS34): slide the battery tab to unlock and pull it, unplug the AC adapter, hold the power button 30 seconds, then boot AC-only with the battery still out. This clears the embedded controller latched shutdown state - the most common "completely dead after overheat" cause on this model.
2. Watch the LEDs with AC plugged in (battery still out): a charging LED lighting means power reaches the board and the fault is downstream; no LED at all points to the adapter, DC jack, or board itself.
3. If it boots AC-only, power off, reseat the battery, and boot normally. If it dies again with the battery in, the battery pack may have been cooked - run AC-only to confirm.
4. Dust: take the bottom cover off (Phillips screws + a plastic pick) and blow out the fan and heatsink fins. Packed fins trap heat on this slim chassis and an overheated VRM can shut the whole board down, which fits a Minecraft session that ended in a hard stop.
5. Still no LEDs on known-good wall power: the DC-in board or main board took the hit. The DC-in board is an inexpensive part if you can measure; otherwise that rung is a repair-shop / multimeter job.
Parts references: Sony manual W0000103M and the SVF14 parts listings list the VGP-BPS34 battery and DC-in board.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Minakshi Sanjay Jathade sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 33
Her zaman: 33
