Replacement micro switches and scroll encoder for Logitech Pebble M350
Subject: Replacement micro switches and scroll encoder for Logitech Pebble M350 (model MR0075)
Hello,
I am repairing my Logitech Pebble M350 wireless mouse (model number MR0075), which I have used for over two years. It has two faults:
1. The left and right click buttons are unreliable. They double-click or fail to register, which I believe indicates worn micro switches.
2. The scroll wheel jumps up and down or scrolls in the wrong direction, which I believe indicates a worn or dirty rotary encoder.
I am experienced with soldering and would like to replace the parts rather than buy a new mouse. I would be grateful if you could advise on the following:
- What are the exact type and dimensions of the click micro switches used in this mouse? Some sellers list Kailh silent switches (6 x 6 x 4.3 mm, 2-pin) as compatible, but I have not been able to confirm this.
- What are the exact type and dimensions of the scroll wheel rotary encoder (body size, pin count and pin spacing)?
- Can you recommend replacement parts (for example Kailh or TTC) that are known to fit this model?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
You might be able to find parts from these places, well-known electronics parts suppliers include DigiKey, Mouser Electronics, Newark Electronics and REM Electronics Supply Company. Catalogs will have specs to compare your measurements of the silent micro switches to lists.
tarafından
Yorum Ekle
