Ana içeriğe geç
Tam donanımlı: kahve, espresso, kapuçino, latte macchiato, sıcak su, sıcak süt. Dokunmatik ekranla basit kullanım.
Simiens eq6 not starting
Machine ain’t working
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I asked FixBot (Ai) your question with its answer in italics. Beware of Ai mistakes.
FixBot's answer
Does the display light up or make any clicking sounds when you press the power button, or is it completely unresponsive with no lights at all?
If the machine attempts to start (such as clicking, flashing lights, or trying to move the internal mechanisms) and then shuts down, it is often caused by:
  • A tripped safety mechanism or short circuit: Moisture inside the machine (often from a leak around the ceramic valve, heater, or flow meter) can cause a short circuit or trip your home's breaker.
  • Blocked mechanisms: A jammed brew group or ceramic valve can prevent the machine from completing its startup cycle.
  • Power supply or control board issues: A faulty main control board or blown internal fuse can prevent power from reaching the system.
Let me know what you observe when you try turning it on so we can narrow down the issue!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Besmir Bacaj sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 24
